Videohub
Ronak Desai
Videohub
on Aug 4, 2013 at 4:25:03 pm
Can anyone confirm if embedded audio in the SDI is also routed to the output or does it end up being stripped out?
Is genlocking required? I don't need to use it to live switch but I don't want any issues with the video/audio being out of sync when I do route signals.
Any general issues I should know about?
Baz Leffler
Re: Videohub
on Aug 4, 2013 at 11:23:07 pm
full 16 channels of audio are part of the routed signal.
Genlock has no part in A/V sync issues - its only there to provide a 'vertical interval' switch reference if sources are genlocked.
Baz
