Ultrastudio 4K input buttons
Mike Halper
on Jul 15, 2013 at 12:10:22 am
I'm considering getting an Ultrastudio 4K. If I have 2 different sources going into the SDI inputs A and B, which would the SDI input button go to? Does pressing the button multiple times cycle between the A and B inputs? If so, which output would I use to monitor the input that's selected on a single monitor.
Basically, I'd like to have to sources going into SDI inputs A and B, but have just one monitor connected to one SDI output and be able to switch between those 2 sources with the SDI input button. Is this possible?
I couldn't find this information anywhere. The website doesn't give detailed info and surprisingly the manual gives zero information about the functionality of the input buttons.
Thanks.
