DecLink SDI AV out for FCP X?
Francois Driessen
on May 28, 2013 at 8:05:03 pm
Hi there. Might be missing something but I'm toying around with FCP X to give it a chance (*after the latest updates to get it pro-ready.)
Somehow my AV out options through the Preferences only gives me one option:
Blackmagic 720 x 486 @29.97
My viewer does output to SDI but only in the above mentioned SD format. Anyone else running the DecLink SDI for HD output with FCPX?
Francois
FireTrigger Inc.
http://firetrigger.com
Francois Driessen
Re: DecLink SDI AV out for FCP X?
on May 28, 2013 at 8:28:26 pm
OK> Solved. (To some extent)
Noticed a subtext in the BM preferences in SYS PREFS that states:
"Final Cut Pro X and startup video output will use this setting"
Seems like FCP X does not see anything beyond what this is set to upon FCPX launch as an AV option. Annoyingly, it seems to only be able to set this upon startup of FCP X. So I can't change AV output on a per "project" basis while FCPX is open... ?
Any ideas?
Francois
FireTrigger Inc.
Bret Williams
on Jun 6, 2013 at 4:49:15 pm
That is correct.
