ATEM ME/1 looses camera
Jim Cunningham
on May 24, 2013 at 1:47:36 am
Occasionally, I’m finding that our ATEM ME/1 will stop seeing a camera plugged into one of the SDI ports. (SD, NTSC – Sony D35, Triax/CCU/SDI – not referenced). The only way that I have found to reacquire the camera is to power off and on the switcher.
This is an intermittent issue, and unfortunately, I haven’t found a way to make it happen. Any ideas what might be causing this, and how to avoid this issue? And is there a way to reacquire a camera that is working, plugged-in, but not visible on the multi-viewer nor Program Out besides recycling power?
I have the most recent software upgrade, and am running the switcher on a MBP 17.
As always, thanks in advance for your collective sage insights.
Cheers,
Jim
