Viewing both fields with fcpx
Boris Deleon
on Apr 25, 2013 at 8:49:54 am
I can see both fields in my viewer, when I play or when I pause in fcpx,
I see both fields when I play, but only one when I pause on my video monitor.
In fcp7 everything works fine,
I am on 10.8.2 with a Decklink 4k, driver 9.7
Thank you in advance
Boris
Chuck Pelini
Re: Viewing both fields with fcpx
on Apr 29, 2013 at 7:27:06 pm
Top right corner of the viewer window has a switch that drops down. "Show Both Fields" is in there.
Boris Deleon
on May 2, 2013 at 9:41:56 am
Yes I know it is there, and I can see both fields in the viewer.
I have also removed the check box field jitter in the blackmagic system preferences.
When using FCP7, I get both fields on a stop frame, in the viewer and on my video monitor,
When using FCPX, I get both fields on a stop frame, in the viewer but not on my video monitor
Sorry if I wasn't clear
Thank you for the reply
