instensity shuttle usb + Mac mini + bootcamp
Alessandro Cofanelli
on Apr 22, 2013 at 1:41:31 pm
has anyone tested to use an usb3 intensity shuttle in a 2012 Mac mini with windows 7 installed (bootcamp)?
i need to have 2 intenity shuttle connected to a mac-mini, but it only have 1 thunderbolt port so i can't use intensity shuttle thunderbolt.
Any other solution?
Top Service Audiovisivi
http://www.topserviceitalia.com
Jim Sustacek
Re: instensity shuttle usb + Mac mini + bootcamp
on Apr 23, 2013 at 12:26:41 pm
Sonnet has a number of products that might fit your needs:
http://www.sonnettech.com/product/thunderbolt/index.html
If you don't find the exact Thunderbolt hub you are looking for, you could also try a Thunderbolt PCIe enclosure with two Intensity Pro PCIe cards installed instead of two Intensity Extreme/Shuttle units.
I haven't done anything like this yet, so you will want to research it further before purchasing (or get a good return policy), but theoretically it should be possible. I would be curious to hear your results if you try this too.
