hyperdeck uncompressed
Ofer Geva
on Feb 22, 2013 at 6:38:17 am
I have a Panasonic AG-AF100. It outputs 8-bit out of it's sdi output. I wanted to know if anyone knows how much bit rate will I get from connecting it to a hyperdeck shuttle 2 and record uncompressed QuickTime?
Paul Lewis
Re: hyperdeck uncompressed
on Feb 23, 2013 at 3:30:37 am
Ofer,
I have some files at home from a BMD Hyperdeck studio,
recorded in SD uncompressed, I am at work right now.
In doing a export of a 1080p uncompressed 8 bit 422 file, both Mediainfo and the quicktime player report around a gig a second.
Here is a chart from a HDV forum,
525 NTSC uncompressed;
8 bit @ 720 x 486 @ 29.97fps = 20 MB per/sec, or 70 GB per/hr.
10 bit @ 720 x 486 @ 29.97fps = 27 MB per/sec, or 94 GB per/hr.
625 PAL uncompressed;
8 bit @ 720 x 576 @ 25fps = 20 MB per/sec, or 70 GB per/hr.
10 bit @ 720 x 576 @ 25fps = 26 MB per/sec, or 93 GB per/hr.
720p HDTV uncompressed;
8 bit @ 1280 x 720 @ 59.94field = 105 MB per/sec, or 370 GB per/hr.
10 bit @ 1280 x 720 @ 59.94field = 140 MB per/sec, or 494 GB per/hr.
1080i and 1080p HDTV uncompressed;
8 bit @ 1920 x 1080 @ 24fps = 95 MB per/sec, or 334 GB per/hr.
10 bit @ 1920 x 1080 @ 24fps = 127 MB per/sec, or 445 GB per/hr.
8 bit @ 1920 x 1080 @ 25fps = 99 MB per/sec, or 348 GB per/hr.
10 bit @ 1920 x 1080 @ 25fps = 132 MB per/sec, or 463 GB per/hr.
8 bit @ 1920 x 1080 @ 29.97fps = 119 MB per/sec, or 417 GB per/hr.
10 bit @ 1920 x 1080 @ 29.97fps = 158 MB per/sec, or 556 GB per/hr.
1080i and 1080p HDTV RGB (4:4:4) uncompressed;
10 bit @ 1280 x 720p @ 60fps = 211 per/sec, or 742 GB per/hr.
10 bit @ 1920 x 1080 @ 24PsF = 190 per/sec, or 667 GB per/hr.
10 bit @ 1920 x 1080 @ 50i = 198 per/sec, or 695 GB per/hr.
10 bit @ 1920 x 1080 @ 60i = 237 per/sec, or 834 GB per/hr.
Of course Your milege may vary....
Perhaps record in the Avid DnxHD codec, gets you about five times the space as opposed to uncompressed.
Cheers,
Paul Lewis
Ofer Geva
on Feb 23, 2013 at 5:49:11 pm
Thank you for the information.
It was very helpful
