3G from decklink to monitor - does it work?
Paul Provost
on Feb 20, 2013 at 11:46:07 pm
I have been trying to send a 3G signal (444 RGB 23.98) from Resolve to my Oled pvm 2541 using decklink hde3d+, and now the new 4K. No Luck. Single link, using 4.5Gig rated cable, monitor is capable, is supposedly level B 3G like Decklink, blah blah blah.
has anybody ever gotten 3G out of a decklink at all to anything? ever?
http://www.4Kfinish.com | owner-colorist | Hollywood, CA
http://www.facebook.com/4kFinish
Frank Gothmann
Re: 3G from decklink to monitor - does it work?
on Feb 21, 2013 at 1:24:41 am
Yep, no problem here with a Decklink Extreme 3D. Going out via 3G 444 at 23.98 works fine going to a JVC Monitor and to an SR-Deck.
I presume you've set the 3G option in the card's preferences, right?
"You also agree that you will not use these products for... the development, design, manufacture or production of nuclear, missiles, or chemical or biological weapons."
iTunes End User Licence Agreement
Paul Provost
on Feb 21, 2013 at 1:41:22 am
Well the davinci guys say Resolve prefs override decklink and to leave those alone. But setting those does not help. What program are you using to play out to sr deck?
Frank Gothmann
on Feb 21, 2013 at 2:33:48 am
Depends. Done it with FCP and Gluetools in the past, not often on Mac anymore these days. Media Express (DPX) and Avid (DnxHD 444) most recently.
Try Media Express and set your Deckling prefs to use 4:4:4. Using that setting my JVC imediately switches to 3G 4:4:4 when I open Media Express. If your display has a signal indicator you will know that it gets the connection and you can troubleshoot from there.
Paul Provost
on Feb 21, 2013 at 4:12:59 am
Thanks guys. I'll try media express again and use decklink prefs. Frank are you choosing both use 444 and use 3G?
What I'm getting in all my test are the pink n green image like one side only of dual link.
Juan Salvo
on Feb 21, 2013 at 2:55:37 am
Yes. I have. I'll check my config for you tomorrow.
Colorist | Online Editor | Post Super | VFX Artist | BD Author
http://JuanSalvo.com
Paul Provost
on Feb 22, 2013 at 3:53:26 pm
Well I tried media express and same issue. Sony pvm oled sees 444 3G but it is green, pink like it is getting one Chanel only. So Sony monitor does not like the decklink 3G.
One note is if signal is 59.94 hd in resolve Sony sees 3G fine, but it displays it is yuv 422
Simon Blackledge
on Mar 15, 2013 at 8:34:08 am
Same here :-/
Have emailed support and they are looking into this for me. Good support as usual.
Surprised not more people have flagged this up :-/
s
Paul Provost
on Mar 15, 2013 at 4:28:07 pm
Please post any results
I've given up
Simon Blackledge
on Mar 22, 2013 at 4:51:48 pm
Shown BM tech in office. Gonna look into it.
Sure it cant be just us 2 ?
Paul Provost
on Mar 22, 2013 at 4:57:21 pm
sure it could be. maybe defective sony pvms. I got mine June last year, so should have latest firmware. Sony tech support (who is almost impossible to reach, takes days of phone calls and left messages and hours of hold time) were of no help whatsoever. they just read the manual back to me and said it should work.
Paul Provost
on Apr 25, 2013 at 7:55:35 pm
it was the sony. just had firmware upgraded and 3G 444 rgb now working. known issue. almost impossible to get info.
