iPad output to DVI extender?
Warren Morningstar
on Jan 8, 2013 at 4:44:56 pm
Is it possible to use the DVI Extender with an iPad? If so, how?
Juan Salvo
Re: iPad output to DVI extender?
on Jan 12, 2013 at 7:13:51 am
Ummmm well no. It's not a DVI device is it? You may be able to accomplish what you want using an appletv and AirPlay.
Colorist | Online Editor | Post Super | VFX Artist | BD Author
http://JuanSalvo.com
Warren Morningstar
on Jan 14, 2013 at 1:10:33 pm
Well, actually it is a DVI device. You can get an adapter from Apple for a DVI output. Turns out, works just fine with the DVI Extender. I discovered the 30 pin plug on my iPad is a little flakey. Wiggle it just right and everything works.
Abigail Cable
on Jan 16, 2013 at 2:29:12 pm
As long as you have a DVI output on your IPad and buy the right type of DVI Extender I don't see any issues. All a DVI Extender does is allow you to extend the distance between your DVI source and display.
Paul Fitzpatrick
on Jan 16, 2013 at 9:46:09 pm
Anyone tried this with the Matrox Convert DVI? I need a scan converter, not an extender, to take my iPad's 60p output and get it to 59.94?
