Monitoring solution - Decklink SDI PCIe VS Intensity 3D?
Reinis Traidas
on Dec 17, 2012 at 8:29:11 pm
Hello.
I'm looking to upgrade my color correction workstation in 2013 assuming that Apple release a Thunderbolt equipped Mac Pro then. Since I assume all of my available PCI slots will be taken with things like Nvidia Quadro 4000 and a Red Rocket card, do you think I could then easily avoid buying an expensive PCI expansion chassis in order to add a Decklink SDI card? I mean, the Intensity 3D Thunderbolt box does the same thing right? I'm looking to use a 10-bit 4:4:4 capable grading monitor with Resolve. I am hoping that the Decklink 4K Extreme 3D does exactly the same thing as Ultrastudio 3D (except the 4K part)...
Is my thinking correct here?
Alex Gerulaitis
Re: Monitoring solution - Decklink SDI PCIe VS Intensity 3D?
on Dec 18, 2012 at 1:31:10 am
[Reinis Traidas] "I am hoping that the Decklink 4K Extreme 3D does exactly the same thing as Ultrastudio 3D (except the 4K part)..."
For the most part, UltraStudio 3D is Decklink Extreme 3D in a Thunderbolt chassis - so I believe it will work exactly the same.
The only caveat is no daisy-chaining with BMD Thunderbolt products - although this may not be an issue as hopefully, the upcoming Mac Pro will have two TB ports, following the current trend.
Alex Gerulaitis
Systems Engineer
DV411 - Los Angeles, CA
