HD Link Pro Video Latency
Edson Cudjoe
on Nov 26, 2012 at 2:59:12 pm
I wanted to know if it is possible to find out the system latency time between the SDI and HDMI connections on the Blackmagic HD Link Pro.
The model has a DVI output and requires a DVI - HDMI adapter. Assuming this is also connected, how much of a delay in video should I expect from the SDI input to the HDMI output? I believe it to be approximately a frame but I do need confirmation as I can't find this information in the product manual.
Thank you
Sareesh Sudhakaran
Re: HD Link Pro Video Latency
on Nov 29, 2012 at 5:03:02 am
As far as I know the only way to know the exact latency is to test it.
http://www.wolfcrow.com - Workflow information and support for filmmakers, photographers, audiographers and videographers.
