Playback device to use with Eizo ColorEdge CG223W
Carl Lohman
on Nov 21, 2012 at 10:43:34 am
Hello!
I have just bought a grading monitor (Eizo ColorEdge CG223W), a Black Magic Intensity Pro and I use Resolve Lite for grading. The problem I had was when I used the intensity pro to playback from resolve, my monitor looked like it had a Pink/Green tint even when I disconnected it from the BM card and used it as a desktop monitor.
I looked on some forums and found out that the intensity pro only outputted YUV and my monitor only supports RGB. I have heard that the BM HDLink 3D Displayport will work, but I'm not completely sure it will.
My question is, will it work and are there any cheaper options?
Bob Zelin
Re: Playback device to use with Eizo ColorEdge CG223W
on Nov 21, 2012 at 4:56:44 pm
you own an EIZO - one of the most expensive monitors, and $470 for the Blackmagic is expensive ?
Bob Zelin
Carl Lohman
on Nov 21, 2012 at 6:32:45 pm
The Eizo ColorEdge CG223W is worth 1499$. The HDLink for 470$ is expensive for me.
