HDlink Pro 3d & 27" apple led
Javier Sanchez
on Nov 17, 2012 at 2:48:52 am
Are those compatible? cause i can't see anything, feeding the HDLINKpro with all the signals i can do from resolve (deckling extreme 3D+) but no image on the 27"... why?
Javier Sanchez
Head Of Technology
Gama Digital
Chris Pearse
Re: HDlink Pro 3d & 27" apple led
on Nov 19, 2012 at 1:03:04 am
Hi Javier,
We have seen problems between the HDLink Pro and the Apple Cinema Displays that use Mini DisplayPort. The older 23 and 30 inch DVI Cinema Displays worked really well, but it seems there's something about the wake function of the newer ones that does not like the HDLink Pro's signal. In the past we have used these monitors with the original DVI HDLink Pro using a converter from DVI to Mini DisplayPort from Atlona, but I just had a quick look and it seems they're no longer producing these. Maybe another active adapter would work, but I'm afraid I don't know of any others that work at this time.
Chris Pearse
Blackmagic Design
