Advice for maintaining 10 bit signal for color correction suite.
Joe Violette
on Nov 16, 2012 at 7:30:34 pm
Hi all,
I am looking into purchasing a Black Magic DeckLink Studio and I am having difficulty determining how to maintain the 10 bit signal so that it reaches out DreamColor and Panasonic SC-BT300. This is a for a mac pro.
Any suggestions on the simplest solution would be a major help. Thank you!
Joe Violette
Re: Advice for maintaining 10 bit signal for color correction suite.
on Nov 16, 2012 at 8:02:24 pm
Also, can I maintain the 10bit signal with a powered HDMI splitter? Thanks again!
Angelo Lorenzo
on Nov 25, 2012 at 8:28:11 pm
HDMI is a digital signal. Splitting the signal will not affect the bit depth so a powered splitter should be fine. It also appears that the Blackmagic Decklink studio is 10-bit HDMI, as some other Blackmagic products are only 8-bit.
Angelo Lorenzo
Need to encode ProRes on your Windows PC?
Introducing ProRes Helper, an awesome little app that makes it possible
Fallen Empire Digital Production Services - Los Angeles
RED transcoding, on-set DIT, and RED Epic rental services
Fallen Empire - The Blog
A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
