No AES/EBU signal coming into ATEM Television studio from Behringer SRC2496 Ultramatch Pro
Aaron Novak
on Nov 10, 2012 at 11:29:17 pm
So this set up used to work for me but now its not. No sound seems to be coming into the ATEM from the Behringer. Im going out of the SRC2496 from the RCA digital out to the ATEM AES/EBU BNC connection.
Settings for the Behringer A/D converter:
Left-side Source button is set to "Analog"
Audio input us shown the level indicators.
The Mode button is set to "A/D & D/A Conv"
The Format button is set to AES/EBU
PLL lock light is on (don't know if that means anything)
Is there some setting I'm missing on the Behringer or the ATEM? I assume I should see the levels going to the ATEM Software Control Sound tab under the EXT channel...
Any ideas?
Lee Stephens
Re: No AES/EBU signal coming into ATEM Television studio from Behringer SRC2496 Ultramatch Pro
on Oct 10, 2013 at 2:45:03 pm
Hi...im having same problem out of the blue... did you fix yours?
