Premiere CS6,Only single fieled is played to external monitor
masashi sato
on Nov 2, 2012 at 7:52:41 am
Hi, I tested PremiereCS6 with Decklink SDI.
Premiere can't play correctly the interlace Sequence ,via Decklink ,in GPU mercury engine mode.
Only single fieled is played to external monitor via Decklink.
I upload the test video.
https://dl.dropbox.com/u/5542662/interlace-test.mov
(16MB, clip)
Please,playback test.
When you play the video via deckling to external monitor in GPU mercury engine mode,
Are there 2 flashing square?
If you play the video correctly, there are 2 flashing square.
If you see no square or 2 white square, Premiere play a only field of the video.
Decklink support PremiereCS6 in only software mercury engine mode?
