Teranex 2D sync reference... & Ethernet control???
Jonathon Lee
on Oct 27, 2012 at 8:52:40 pm
Does the Teranex have an internal sync generator? I'm using it via TB to playback a video file @ 29.97 SD and uprez'ng to 23.976 1080p. If I free run the Teranex is it stable? And on the record device, a BMD Decklink HD dual-link, is it sufficient to lock that to input?
On the original Teranex vc300 you had to use external reference... is this true for the BMD units?
ALSO... there's an ethernet port, but it appears to be inactive. The vc300 had a web applet to control the unit. Is there such an implementation on the BMD units?
thank you!
Jonathon
Bob Zelin
Re: Teranex 2D sync reference... & Ethernet control???
on Oct 28, 2012 at 2:02:19 am
the ethernet port is not active "yet" - "soon". Yes, this is very important.
Bob Zelin
