Blackmagic Ultrastudio 3d - Video Output to Eizo CG27W Coloredge
Crescenzo Mazza
on Oct 25, 2012 at 9:12:59 pm
Just arrived a couple of EIZO Coloredge CG27W, to complete the following editing setup:
- Imac 27 late 2011;
- Apple Thunderbolt Display;
- Blackmagic Ultrastudio 3D;
Eizo has DVI-D input, mini display port and display port.
What is the solution to playback 1080 material on Eizo starting from Ultrastudio 3d?
- HDMI to DVI-D cable: no signal;
- Blackmagic HDLINK PRO?
- AJA HDP2?
- GEFEN SDI to DVI adapter?
- KRAMER VP-471
The Eizo works perfectly attached via thunderbolt mini display port but I need to use it via broadcast card.
Thanks in advance for help.
Crescenzo
Alex Gerulaitis
Re: Blackmagic Ultrastudio 3d - Video Output to Eizo CG27W Coloredge
on Oct 25, 2012 at 10:06:02 pm
[Crescenzo Mazza] "What is the solution to playback 1080 material on Eizo starting from Ultrastudio 3d?
- HDMI to DVI-D cable: no signal;"
I suspect (but could be dead wrong) that UltraStudio outputs 1080p29.97 or 1080i59.94 that Eizo can't sync to over DVI. I'd try HDMI-to-DP, since DP spec supports a wider range of frame rates than DVI. If that does not work, I would try one of the converters you mentioned.
Alex Gerulaitis
Systems Engineer
DV411 - Los Angeles, CA
Luca Salmy
on Nov 26, 2012 at 12:34:53 am
I've now the same your problem!!!
I've to playback 1080 material on Eizo starting from Ultrastudio 3d!
How have you resolved the problem??
THANKS very much!!
