ATEM 1 M/E Audio Pass through
Kirk Baggott
on Oct 25, 2012 at 3:41:27 pm
Does the ATEM 1 M/E have audio pass through? If so, does it pass audio through from each source or only PGM audio? Specifically, if I route 4 different sources to the outputs (1 to PGM and 3 each to AUX) do they all get source audio or PGM audio?
Ideally I would like for audio and video from source 1 to be output through AUX 1, audio and video from source 2 to be output through AUX 2, etc. Is this possible?
Justin Strauber
Re: ATEM 1 M/E Audio Pass through
on Oct 26, 2012 at 2:52:17 pm
Not possible that i've seen. All of the outputs are PGM audio, with the exception of the analog outs, that can now be switched to a 'Monitor' out from the audio panel of the switcher. There is no internal audio routing other than the mixer itself.
You may need a small HDMI or SDI router external from the ATEM to do what you're trying to do.
