Teranex ultrascope
Paul Provost
Teranex ultrascope
on Oct 22, 2012 at 5:46:53 am
As it seems bmd is never going to release a standalone thunderbolt ultra scope for Mac, I want to get a teranex for this and conversion uses. This would be for external scopes on a davinci system. I would go out of my davinci decklink into the teranex, then out of the teranex thunderbolt to my 17" Mac Pro for ultrascope software. The teranex manual says the ultrascope is the output of the teranex. Is there a way to monitor the input or pass through?
Edit, after re reading the manual, there is a second section where it says you can set output match input. Is this true pass though with no processing?
http://www.4Kfinish.com | owner-colorist | Hollywood, CA
Michael Sacci
Re: Teranex ultrascope
on Oct 23, 2012 at 4:09:37 am
Anwered in other post but yes it works great, you have full control over the teranex when you launch UltraScope
Paul Provost
on Oct 23, 2012 at 4:26:19 am
Is there a passive pass through mode?
Paul Provost
on Oct 23, 2012 at 2:34:51 pm
Bmd support just confirmed no passive mode, so teranex useless for monitoring input signal by ultrascope / thunderbolt.
Now to see if mini recorder / ScopeBox will work...
