powering blackmagic converter with v-lock battery
TimVideo Ahern
on Aug 29, 2012 at 10:46:34 pm
I am looking at getting a little connector made to go from the d-tap connecter on a v-lock battery mounting plate to my Blackmagic Design mini converter (SDI-HDMI). All the V-lock batts are 14.8v, the mini converter is 12v.
Will the difference in voltage blow up my mini converter?
Hersh Burston
Re: powering blackmagic converter with v-lock battery
on Aug 30, 2012 at 11:36:48 pm
Unfortunately Mini Converter SDI to HDMI cannot accept a 14.8V input. There are many third party D-Tap regulated connectors available. A Google search should find these for you.
Regards,
Hersh Burston
Senior Product Manager
Blackmagic Design
Patrick Sproule
on Aug 31, 2012 at 7:40:48 am
We ran a bunch of them off 12v 4ah Gel Cells in the field - in particular the optical to SDI convertors. They ran for a full 8 hours without recharge. Might be a suitable option?
Pat
