Alienware - ATEM Television Studio - Wirecast
Glenn Garnes
on Aug 29, 2012 at 1:59:59 pm
Does anyone have any experience with whether the ATEM Television Studio will work on an Alienware computer with Wirecast as the virtual switcher? Here is my configuration on the computer:
OS including service pack and 32/64bit Windows 7 64 bit
-Computer and CPU: Alienware Area 51
OS Name Microsoft Windows 7 Ultimate
Version 6.1.7601 Service Pack 1 Build 7601
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name GGALIEN
System Manufacturer Alienware
System Model Area 51
System Type x64-based PC
Processor Intel(R) Core(TM) i7 CPU X 990 @ 3.47GHz, 3468 Mhz, 6 Core(s), 12 Logical Processor(s)
BIOS Version/Date Alienware A10, 11/9/2010
SMBIOS Version 2.5
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume2
Locale United States
Hardware Abstraction Layer Version = "6.1.7601.17514"
User Name GGALIEN\Glenn K. Garnes
Time Zone Eastern Daylight Time
Installed Physical Memory (RAM) 12.0 GB
Total Physical Memory 12.0 GB
Available Physical Memory 9.82 GB
Total Virtual Memory 24.0 GB
Available Virtual Memory 21.3 GB
Page File Space 12.0 GB
Page File C:\pagefile.sys
-Graphics Card :
Primary Adapter
Graphics Card Manufacturer Built by AMD
Graphics Chipset AMD Radeon HD 6990
Device ID 671D
Vendor 1002
Subsystem ID 0B2A
Subsystem Vendor ID 1002
Graphics Bus Capability PCI Express 2.0
Maximum Bus Setting PCI Express 2.0 x16
BIOS Version 013.011.000.014
BIOS Part Number 113-C2060100-104
BIOS Date 2011/02/14
Memory Size 2048 MB
Memory Type GDDR5
Core Clock in MHz 830 MHz
Memory Clock in MHz 1250 MHz
Total Memory Bandwidth in GByte/s 160.0 GByte/s
Linked Adapter
Device ID 671D
Vendor 1002
Subsystem ID 1B2A
BIOS Part Number 113-C2060100-105
Memory Size 2048 MB
Memory Type GDDR5
I would like to feed 3 or 4 Canon Vixia HG20's into the ATEM Television Studio and use Wirecast to switch between them just as if they were on separate cards within my computer. Please advise.
Alessandro Cofanelli
Re: Alienware - ATEM Television Studio - Wirecast
on Aug 29, 2012 at 3:29:31 pm
you can't do what you need.
ATS is a standalone hardware switcher, not a computer card.
You can control ATS from the computer using the provided software or using the sdk, but you can't use wirecast to control atem.
You can use wirecast to live stream or record output video coming from the ATM.
Top Service Audiovisivi
http://www.topserviceitalia.com
Glenn Garnes
on Aug 29, 2012 at 4:04:49 pm
So, what would I use to do green screen/virtual sets if I can't use Wirecast?
Justin Strauber
on Aug 29, 2012 at 10:19:04 pm
You would either need an ATEM 1 M/E or 2 M/E and do the chroma key in that, or separate video capture cards for each camera. The TVS is a switcher, not a multi-port capture card.
