Record tv shows on blackmagic hyperdeck?
Ed Bee
on Aug 24, 2012 at 10:55:32 pm
Can I record from tv to blackmagic via HDMI?
Aleksander Steffensen
Re: Record tv shows on blackmagic hyperdeck?
on Aug 25, 2012 at 8:06:00 am
If your tuner or whatever sends the HDMI signal does not use HDCP, it should work just fine.
Steffensen Multimedia
Ed Bee
on Aug 25, 2012 at 11:45:31 pm
And how do I find that out? My tv is hd 1080p with dual HDMI outs, USB port, what is hdcp?
on Sep 2, 2012 at 10:46:13 am
HDCP is copy protection. As long as the source signal is not copy protected, the HyperDeck will be able to record it just fine.
Ed Bee
on Sep 2, 2012 at 6:08:19 pm
My friend you are speaking in Chinese. All I know about my tv is that it is a RCA 1080p HD, it says nowhere that I can see copy protect. Please speak in layman terms as not all of us are tech savy like you. How do I find out if my tv is copy protected like you said.
Josh Guerette
on Oct 24, 2012 at 3:54:48 am
I haven't been able to find any RCA HDTVs that have HDMI outputs on them, only HDMI inputs. If you could provide your model number, I can look a little further, but it seems unlikely they are outputs. Even if they were, they are almost always HDCP copy protected, meaning the recording device has to "decode" the video signal. The Hyperdeck does not support that HDCP decoding, so therefore cannot see or record the video signal.
Also, HDCP is a very common standard, and is present on the HDMI connections of all major televisions nowadays. If you wish to record high-definition outputs, you should probably look at HD Component outputs, which are also common on most consumer video devices (Red, Green, & Blue cables).
