HyperDeck Shuttle does't playback audio from DNxHD file
Tho Nguyen
on Aug 20, 2012 at 2:26:23 pm
Hi all,
I have copied a DNxHD-Quicktime file, redered by Avid Media Composer 5 (MAC) to the SSD. HyperDeck Shuttle 2 played back the video only (1080i/25), but not the audio (PCM 48 Khz).
This file can be played back on Mac and Windows PC without problem.
When record the film via HDMI-Input, the audio is ok.
Any idea?
Chris Hand
Re: HyperDeck Shuttle does't playback audio from DNxHD file
on Aug 20, 2012 at 3:36:55 pm
I am in the same boat, I have tried every different combination of audio settings for DNxHD audio to work correctly and have failed. I have pretty much given up on it until Blackmagic hopefully releases an update or gives specific instructions on how to actually create a DNxHD file that will playback correctly.
Russell Shaver
on Nov 27, 2012 at 9:35:02 am
Interested in using the Shuttle as a playback device also. Wondering if you were ever able to get the shuttle to playback audio?
