ATEM 1 M/E doesn't laptop as HDMI source
Matt Drabick
on Aug 17, 2012 at 9:19:16 pm
I setup an ATEM 1 M/E as a demo system in my shop. I am using the very same laptop that normally connects to my ATEM Television Studio. My Television Studio sees the output of my laptop as an HDMI source. When I connect the same laptop to any of the four HDMI inputs on the 1 M/E the laptop isn't seen.
I have connected the HDMI output from my TriCaster 855 into the 1 M/E and the 1 M/E sees the HDMI output from my TriCaster 855.
I connected a second computer with an HDMI output and my ATEM 1 M/E didn't see the computer as an HDMI input.
Do I have a 1 M/E with flaky HDMI inputs or is this something else.
I am running the ATEM 3.2 software on the host PC . . . .
Remember, my Television Studio sees the HDMI output of my laptop using the same host computer driving the 1 M/E.
Matt Drabick, DigiTek Systems
Eric Harrison
Re: ATEM 1 M/E doesn't laptop as HDMI source
on Aug 19, 2012 at 12:24:49 am
Same thing happened to me. What worked for me was to install the 3.1.2 drivers.
If you have a mac, go to here
If you have a PC, go to here
I did talk to BMD support on the phone and explained that 3.2 didn't work. I would do the same if I was you just so they know that other people are having the same issue.
Nathan Wright
on Aug 19, 2012 at 9:00:35 pm
We are having the same issue on 3.2 with the hdmi on multiple units
Eric Harrison
on Aug 20, 2012 at 5:54:29 pm
Just talked with BMD and they said that they have had several calls about this issues. What they said is that the switcher is looking for a 59.94fps signal but if the signal is 60 then that's fine too. Computers use a normal rate of 60Hz for monitors. 60Hz = 60fps. But with this new update that tolerance is tighter to where the 60Hz not's match. They are working on trying to fix it.
Liam Kennedy
on Aug 21, 2012 at 7:13:56 am
That is welcome news to hear BM recognizes the issues (I've reported the issues... but not received a reply).
This is a BIG issue for many of us I think. The 3.2 Firmware has effectively broken all of the scalers/converters I use to bring various devices in to my ATEM 1ME. No longer functioning are my Altona VGA to HDMI, Gefen Toolbox HDMI Scaler, Apple TV (3rd Gen).
I also have a TVS... and the 3.2 firmware did not break the HDMI compatibility.
I do hope they fix this soon.
Eric Harrison
on Aug 22, 2012 at 5:38:20 am
Got an email from BMD saying that they now have their own Forum. Here's the link
http://forum.blackmagicdesign.com
