Recording the DVI out from a PC
Gary Jones
on Aug 7, 2012 at 2:48:35 pm
Hi all,
Bit of a longshot here, but:
If you set the graphics card output to 1920x1080 at 50Hz, converted the DVI to HDMI, could the Hyperdeck Shuttle record the signal? I am trying to solve a problem of recording the desktop (under linux, mac, & windows) without putting a strain on the machine.
- Gary Jones
Aleksander Steffensen
Re: Recording the DVI out from a PC
on Aug 8, 2012 at 8:29:59 am
You would have to output interlaced for it to work in that resolution. Here is a list of supported formats, look under the "HD format support" section:
If you need progressive video, you can't do 50 Hz.
Steffensen Multimedia
Richard Freemantle
on Aug 9, 2012 at 1:53:44 pm
Hi Gary,
My solution to this problem was:
H264 Pro-Recorder +
GFX Card (NVidia) with HDMI out (nb. DVI>HDMI was v.problematic) +
MX Light
This allows me to record the output of the GFX card at 1920x1080p @ 60Hz on the same machine with a CPU overhead of about 2-4%. The H264 Pro-Recorder records at upto 30Mbps h264/aac, which although compressed is enough for my purposes (tutorial videos).
In fact, I wrote MX Light initially to solve just this problem.
MX Light is currently windows only, so for recording linux/mac desktop output you would need to run MX Light in a VM or use a second machine. nb. You dont need a powerful machine to record with, as the encoding is done in hardware & the data rate is low enough for normal/cheap hard drives.
Hope this helps.
© 2018 All Rights Reserved
