Decklink HD extreme with Media Composer 6 - hardware crippling the AVID?
Chris Oben
on Aug 5, 2012 at 12:52:32 am
Created an MC6 project: 1080p/25
When I select the project to load it, MC6 hangs and gives me an error message:
AMEResourceManager::ReconfigHW_LegendBoB_play()
Error [2147483656] unable to:
SetVideoFormatBlk.
This system has a BlackMagic Decklink HD Extreme for HDSDI monitoring.
Any suggestions. I do not need the video out for this project. Is there a way to disable the hardware output of MC?
Chris M. Oben
Chris M. Oben
http://www.chrisoben.com
Richard Lapthorn
Re: Decklink HD extreme with Media Composer 6 - hardware crippling the AVID?
on Aug 23, 2012 at 11:30:05 am
Hi Chris,
Which version of MC6 are you using and which version of the Blackmagic drivers?
The latest update to MC6 allows you to switch off hardware support, however what you are describing doesn't sound normal and I reckon should be fixable
Ken Evans
on Aug 30, 2012 at 11:32:02 am
Hi I'm having some Avid issues regards this problem. How do you turn off the hardware support from within MC6?
Senior Technician, Moving Image Department - Kingston University London.
Richard Lapthorn
on Aug 30, 2012 at 2:05:51 pm
Hi Ken, the latest Avid update 6.03 allows you to easily switch between hardware and software modes.
Ken Evans
on Aug 30, 2012 at 6:17:19 pm
Yes but where is this within the app?!
K.
