CRT monitoring solution
Shawn Strong
on Jul 24, 2012 at 1:12:11 pm
I have a 2010 MacPro 2.4G 8-core (12G RAM) w Radeon HD 5870, using FCPX to Davinci Resolve and want to monitor on a Sony PVM-14N6U. Is this possible? Nothing above HD.
Richard Cooper
Re: CRT monitoring solution
on Jul 28, 2012 at 9:52:40 pm
The Sony PVM-14N6U is a standard def monitor so you wont be able to monitor in HD but if SD is all you need, then you just need to get a Black Magic i/0 card to send a proper NTSC video signal out from FCX to our Sony PVM-14N6U. No way you can (or should for that matter) monitor from your Radeon HD 5870.
Good Luck!
Richard Cooper
FrostLine Productions, LLC
Anchorage, Alaska
http://www.frostlineproductions.com
