Setting up reference monitor with Deck Link Studio
Jay Lloyd
on Jul 18, 2012 at 2:50:08 pm
Hi all,
I am trying to set up a reference monitor with After Effects CS5 using Deck Link Studio 2 via SDI on a Mac Pro.
In the system preferences:
Set output: All video, 4 analog audio & 2 AES/EBU
Set input: SDI Video & SDI Audio
Use video set up at in NTSC: at 7.5 IRE for use in the USA
checked: Use 1080p no 1080PsF
checked: Remove field jitter when video is paused
Set default video standard as: HD 1080p 25 (Which is the format I usually work in)
When not playing video: Black
In AE preference:
Output Device: Blackmagic Video Output
Output Modes: (this is where I have problem)
My comp is set to HDTV 1080p 25fps. But I couldn't find a matching setting in the output modes drop down menu . I tried many settings, but none of them give me the result I was expecting. It either has this subtle but unbearable flickering/strobing or terrible interlacing(because I tried to set to to 50i).
Does anyone have similar experience ??
