Webcam issue when using Desktop Video
Warren James
on Jul 17, 2012 at 3:22:51 pm
Hello All,
I am currently working on a project that involves using a webcam and an Intensity Pro card.
The webcam I am using is working from the default Windows Webcam driver.
If I install the webcam before Desktop Video the webcam is fine.
After installing Desktop Video the frame becomes cropped.
I have tested this with another webcam that also uses the default driver and the same happens.
I am using Desktop Video 9.5.3 although I think when I initially saw the problem I was using 9.5.
The machine I am using is Windows XP.
Has anyone seen anything similar or have any ideas for a work around.
Afsheen Aziz
Re: Webcam issue when using Desktop Video
on Jul 17, 2012 at 7:08:59 pm
searching the rght solution also...
if i'll get to know .. will inform you
