Avid MC6 and Hyper Shuttle DNxHD 185 problem
pekin azer
on Jun 29, 2012 at 1:21:07 pm
Hi, i just upgraded to avid mc6 so i can use the footages i shot with the Sony F3 and hyper shuttle 2...
i am planning on shooting my first siver screen film! i want to use The hyper shuttle 2.
But, my PC based Avid mc6 can see the files, but, when i try to play them the footages won't play and they look damaged. But, i can hook the shuttle via hdmi or hd-sdi to any monitor and all the material is good.
what am i doing wrong?
Pekin
Andreas Wojtaschek
Re: Avid MC6 and Hyper Shuttle DNxHD 185 problem
on Jun 30, 2012 at 12:20:25 pm
Make sure to copy all files from your hyperdeck SSD to the mxf media folder of you Avid system. Then go to the Avid mediabrowser and import the files into a bin. You can simply drag them into a bin.
Make sure that the hyperdeck is set to dnxhd mxf file creation.
Regards
Andreas
Entertainment Producer IHK
mindandvision
pekin azer
on Jun 30, 2012 at 5:27:22 pm
Thanks for the help, but, it's not happening....
Davinci Resolve doesn't see the mxf's either... i don't know the version but, a friend's davinci only saw the QT 1:1 files...
What do i do? is anyone working with these mxf files.... i want my P2 panasonic!!!
Andreas Wojtaschek
on Jun 30, 2012 at 7:40:30 pm
Check your workflow - It's working without an issue here.
Cheers
Andreas
mindandvision
