BMV 9.5.2 drivers and Premiere Pro CS6.0.1
Robin Moran
on Jun 11, 2012 at 6:39:26 am
Video is not coming out of Premiere CS6 but is coming from every other app. I didn't have this problem with CS6 or BMV 9.5.1. Anyone else experiencing this?
Robin Moran
Re: BMV 9.5.2 drivers and Premiere Pro CS6.0.1
on Jun 11, 2012 at 7:20:14 am
Managed to uninstall, and reinstall drivers. Now working.
New problem. Working on a ProRes timeline with 720p23.98 footage. Decklink not outputting on broadcast monitor. However, using a DSLR timeline, footage is outputting on monitor?? Weird.
Jeff Kosmicki
on Jun 11, 2012 at 5:45:52 pm
23.976 and 29.97 fps 720p timelines do not currently output through BM cards. It's a bug and I told BM support before 9.5.2 came out but I guess they did not fix it yet, too bad because I do a lot of 720p work that currently has to be done with CS5.
Jeff Kosmicki
http://www.toyraygun.net
Kim Wang
on Jul 4, 2012 at 2:55:43 pm
I have the same problem with intensity pro. No video out with 720P sequence. But 1080p sequence work fine.
Window 7
GTX 470
24G RAM
Premiere pro CS 6.0.1
intensity pro
BMD’s Desktop Video 9.5.3 for Windows.
Called BMD. The support told me I cannot have CS5.5 & CS6 on the same machine. I should get a new pc and install CS6 only. He explain their installer looks for the first PP they find and install it there. I asked if I can manually copy the plugin to the proper folder. He replay “no. just gets a new PC. “ I have amazing experience with BMD before. He must be having a bad day. I also ask if a fix is coming. He relay “No”.
I think its bug, hopefully it get fixed soon.
BTW work fine on After effect CS 6.
Kim W
