Multibridge Pro capture via SDI.
Javier Lopez
on Jun 5, 2012 at 1:40:47 am
Hello Gentleman,
I am trying to capture with the Multibridge Pro SDI, but I can not get it to recognize the signal, is there a specific way to set Multibridge in order to capture?.
Thanks in advance for the advice.
Paolo Castellano
Re: Multibridge Pro capture via SDI.
on Jun 5, 2012 at 7:48:55 pm
Hello Javier,
what is the software you're using to capture?
If you're using Media Express under Windows;
Control Panel>HW&Sound>Settings>Set Input
Best Regards,
Paolo.Castellano@ivs.it
http://www.ivsEdits.com
"Post Fata Resurgo"
Javier Lopez
on Jun 5, 2012 at 8:55:19 pm
Hello Paolo,
I appreciate your time and response, I am using Media Express 3.1 for MAC Lion 10.7.4, I can not get Media Express to recognize the signal.
Regards,
Javier.
Margus Voll
on Jun 6, 2012 at 5:49:59 am
what is the source?
with sony wtr's you have to turn off sony metadata by sdi from menu to make sdi to work
properly.
Margus
http://iconstudios.eu
DaVinci 8.2.1 OSX 10.7.3
MacPro 5.1 2x2,93 24GB
GTX 470 / Quadro 4000
Multibridge 2 Pro
Javier Lopez
on Jun 6, 2012 at 4:03:19 pm
Hello Margus,
The source is SDI out from a Panasonic HPX300 camera.
Thanks for your time.
Margus Voll
on Jun 6, 2012 at 4:08:05 pm
Can you have sdi working with monitor or other gear ?
Margus
Multibridge 2 Pro
Javier Lopez
on Jun 6, 2012 at 4:13:39 pm
Hello Margus,
Yes, it works just perfect with other gear. The inputs an outputs on the Multibridge Pro are pre configured or we have to configure?.
Thanks.
Margus Voll
on Jun 6, 2012 at 4:18:23 pm
What does your Multibridge prefs say ?
Have you SDI in active as there could be component etc?
Margus
Multibridge 2 Pro
Javier Lopez
on Jun 6, 2012 at 9:03:10 pm
Hello,
If you refer to the Multibridge Utility settings, here you have a link to a scree capture, I can not make modifications, I think in order to make changes Multibridge has to be connected trough USB, I currently have it connected trough PCIe.
Thanks.
Paolo Castellano
on Jun 7, 2012 at 8:27:20 am
Hello Javier,
the Multibridge Pro is a fantastic "DUAL USE" device.
If you don't connect it to your PC/MAC using the PCI-e adapter, it works as a dual channel converter from Analog to SDI and from SDI to ANALOG. To configure the conversion you have to connect once the Multibridge to your PC/MAC via USB 2.0, and you will use the "Blackmagic Multibridge Utility" (your screen capture).
When you connect the Multibridge to your PC/MAC using the PCI-e adapter, it becomes a capture device, very similar to the Decklink HD Extreme 2, and you can configure it using "Blackmagic Desktop Video 9.5.2" software, that you can run:
‚‚- On Mac OS X, open the System Preferences and look in the “Other” category to locate the Blackmagic Design icon. Click the Blackmagic Design icon to gain access to the settings.
‚‚- On Windows 7, open the system Control Panel and click on “Hardware and Sound” to reveal the Blackmagic Design Control Panel. Click the Blackmagic Design Control Panel to gain access to the settings.
You can set the input in the "Settings" Tab.
In my opinion the Multibridge Pro is the best product ever made by BMD, the only missing thing was (and is) the lack of a dedicated PCI-e adapter for laptops (express card) and now for Thunderbolt.
Best Regards,
"Post Fata Resurgo"
