Media Express doesn't open
Lutfi Zeton
on May 29, 2012 at 9:18:07 am
First of all, thank you for your support.
Yesterday afternoon, suddenly, when I try to open Blackmagic Media Express in my Mac Pro, it crashes unexpectedly and it shows a crash log. I use it everyday!
This happens when it tries to contact with my Blackmagic Intensity Pro (I think so, because when I'm using it in another software and I try to open Media Express, it shows a warning that my capture is being used). The capture device works perfectly in other softwares such as Premiere.
I have uninstalled everything, even libraries. Restarted more than 3 times and still the same problem.
I'm using OS X Lion 10.7.4 under a MacPro 3,1, 10gb RAM and SSD. Everything went perfect!
The only option I think is format. But that's not a good option...
What should I do? If you need crash log, I will paste it!
Thank you!
Lutfi Zeton
Re: Media Express doesn't open
on May 29, 2012 at 2:07:52 pm
SOLVED: I deleted the Media Express preferences file from Library/Preferences and rebooted. Everything goes perfect ;D
