SD-HDMI minii converter dip switch question
Anhtu Vu
on May 19, 2012 at 10:24:47 pm
I'm using the SDI to HDMI mini converters to convert 23.98 PSF to P signal so i can monitor on the Dreamcolor or Panny via their HDMI input. I edit with Avid symphony using a Kona 3G.
Anyone knows what are the dip switch settings for the above config ?? At the moment, everything is at ''on''. The pic and sound does not seem very tight. Thanks
Chris Pearse
Re: SD-HDMI minii converter dip switch question
on May 21, 2012 at 12:40:49 am
Hi Anhtu,
The DIP switches on the Mini Converter SDI to HDMI shouldn't alter the video conversion, they're really just used for audio, and the Processing switch currently does not do anything. The converter should always convert 23.98PsF to P. However I would suggest leaving the DIP switches in the default OFF position, and switch ON only those switches you need for the settings you require, based on the diagram on the underside of the unit.
If you are still having problems I would suggest contacting your regional support team either using the phone numbers on the following page
http://www.blackmagic-design.com/company/
or using the support request form on the product's page in the support section of the website here
http://www.blackmagic-design.com/support/
Chris Pearse
Blackmagic Design
