DB 25 cable
Sean Davison
DB 25 cable
on Apr 30, 2012 at 4:40:53 pm
Where oh where can I get a DB25 AES to XLR cable so I can get de-embedded audio out of my Multi bridge pro?
I have a Tascam one but it doesn't work - Yamaha any one (Im in the UK)
Life on the Bleedin' Cutting Edge....
Juan Salvo
Re: DB 25 cable
on Apr 30, 2012 at 4:42:36 pm
Hosa makes one & b&h carries it. Don't know if they're us only.
online editor | colorist | VFX | BD author
Jeff Hartman
Re: DB 25 cable
on Apr 30, 2012 at 9:34:27 pm
If you're so inclined, it's pretty easy to make your own cable. Here are the pinouts per the Multibridge manual:
AES IN 1: pin 1 high, pin 14 low, pin 10 ground
AES IN 2: pin 2 high, pin 15 low, pin 12 ground
AES IN 3: pin 3 high, pin 16 low, pin 13 ground
AES IN 4: pin 4 high, pin 17 low, pin 22 ground
AES OUT 1: pin 5 high, pin 18 low, pin 23 ground
AES OUT 2: pin 6 high, pin 19 low, pin 24 ground
AES OUT 3: pin 7 high, pin 20 low, pin 25 ground
AES OUT 4: pin 8 high, pin 21 low
They don't indicate a separate ground for AES out 4, but any of the other ground pins should work fine.
At the opposite (XLR) end, high connects to pin 2, low to pin 3, and ground to pin 1.
This is the same pinout that Yamaha, Mackie, Sony, and Apogee use -- and it's distinctly difference from the Tascam DA88 protocol.
You can find the manual online at -- the pinout is on page 32.
Jeff Hartman
Engineering Project Manager
Newport Television, Northeast
© 2018 All Rights Reserved
