HDLink Pro DisplayPort 3D with 24" Apple LED Cinema display
Neil Sadwelkar
on Apr 30, 2012 at 11:03:46 am
I'm trying this…
Blackmagic HD Extreme 3D feeding HD-SDI into a HDLink Pro 3D DisplayPort
At the DisplayPort of the HDLink Pro I've connected a Gefen DisplayPort to mini DisplayPort female adapter. This one…
http://www.gefen.com/kvm/dproduct.jsp?prod_id=9931
And I've connected mini DisplayPort female port to an Apple 24" LED Cinema Display. It's the old one not Thunderbolt.
I've done the firmware update on the HDLink Pro, power cycled after 5 sec.
Yet, I get no display on the Apple 24" LED Cinema Display.
The HD-SDI output of the HDLink Pro does show an output and can be seen on a Panasonic HD-SDI LCD pro monitor. So my FCP settings etc are fine. And the HDLink Pro seems to be working.
The Apple 24" LED Cinema Display itself works fine when connected to the MacPro directly.
The HDLink Pro 3D DisplayPort and Gefen DisplayPort to mini DisplayPort female adapter are brand new bought from B&H in NY last week.
Does anyone use the HDLink Pro in this manner? With an Apple 24" LED Cinema display?
Or even a 27" LED Cinema Display (non-Thunderbolt). I have access to one and can try it out.
Neil Sadwelkar
neilsadwelkar.blogspot.com
twitter: fcpguru
FCP Editor, Edit systems consultant
Mumbai India
Neil Sadwelkar
Re: HDLink Pro DisplayPort 3D with 24" Apple LED Cinema display
on May 2, 2012 at 6:34:12 pm
OK so I've confirmed this.
The Apple 24" and 27" LED Cinema Display (non Thunderbolt) do NOT work with the Blackmagic HDLink Pro 3D DisplayPort.
What does with with this setup is a Benq 27" display.
It works perfectly fine when connected with the Blackmagic HDLink Pro 3D DisplayPort via a DisplayPort to mini DisplayPort adapter and a mini DisplayPort to HDMI adapter in series.
Bottom line...
Blackmagic HDLink Pro 3D DisplayPort is not compatible with any Apple 24" and 27" LED Cinema Display (non Thunderbolt).
Maybe the Blackmagic HDLink Pro DVI may be compatible, but I haven't tried it.
Neil Sadwelkar
twitter: fcpguru
Mumbai India
