ATEM Television Studio Camera Inputs
Armando Irias
on Apr 22, 2012 at 9:50:28 pm
I am interested in purchasing the ATEM Television Studio to switch three cameras. The cameras I have been working for the past few years are the Sony PD-170 which have a composite video out. Is there a way which I can still use these cameras with the Television Studio? What kind of converter would I have to acquire to input the video into the Television Studio? Is this possible?
Brock Raum
Re: ATEM Television Studio Camera Inputs
on Apr 23, 2012 at 10:39:51 pm
You would need component to either HDMI or HD-SDI converters because those are the only inputs available on the TVD. The ATEM 1 has 1 component input but it would be cheaper just to buy a few converters which black magic sells as well.
Samuel Coman
on Jun 9, 2012 at 8:10:48 am
I have a question. If my cameras have already hdmi output, may I use them with the ATEM TVS?
Shouldn't I pay attention to the ATEM input resolution and cameras resolution?
The specs of the ATEM TVS say:
HD Format Support 1080i50, 1080i59.94, 720p50, 720p59.94
SD Format Support 625/25 PAL, 525/29.97 NTSC
Does this mean that I have to choose video cameras which have the exact resolution?
I'd like to buy these cameras but I'm afraid they aren't compatible:
http://www.bhphotovideo.com/c/product/761898-REG/Canon_HFG10E_Legria_HF_G10...
http://www.bhphotovideo.com/c/product/828522-REG/Canon_5118B005AA_LEGRIA_HF...
http://www.bhphotovideo.com/c/product/846802-REG/Panasonic_HDCSD800E_PAL_HD...
So, what do you think?
Carlos  A. Vazquez II
on Jul 23, 2012 at 8:04:27 pm
Hy Samuel
I had the same issue!
did you had any results???
i have an sx40hs
and i haven't been able to see it
trough my atem tvs!
Samuel Coman
on Jul 23, 2012 at 9:39:05 pm
I haven't bought the ATEM TVS yet. I don't have enough money at this time. But I have done some more research. As far as I can see, the only way you may use the SX40HS and the ATEM TVS together is by setting BOTH OF THEM at 720p and nothing else. Didn't see the camera is able to output 1080i or the ATEM to input the 1080p. So your only try is to set them on 720p. Good luck and leave a reply if it worked! :D
on Jul 23, 2012 at 10:48:51 pm
Wow!
I have very little experience on video
i ve done audio all my life
but i want to learn video so i bought
the atem tvs and I'm looking or cameras
but i still testing !
so theres a difference between 1080p and 1080i???
that seems to be the situation ????
Samuel Coman
on Jul 24, 2012 at 9:13:51 am
I'm not an expert either. I've learned a lot in the past year while doing research regarding the TVS and compatible cameras.
There is a difference between i and p for sure. More details you may find on wikipedia. Here is an useful link:
http://en.wikipedia.org/wiki/1080i
I've had some trouble finding compatible cameras because of those inputs. There are some websites where you may find some more details and help:
http://atemuser.com/forums/atem-vision-mixers/blackmagic-atems/tvs-supporte...
http://atemuser.com/CompatibleEquipment
on Jul 24, 2012 at 8:11:17 pm
Thank you Sam!
Iknew that was something to do with that!
cause I know by a fact
that atem tvs is very picky about input signal
does not like it to have different rates of any kind
i had this canon vixi a hfr30 and works great @ 1080 from stem
but this other canon i mentioned before does not work as a signal imput for video.
i have the atem tvs i love it its just a matter of time
and i will be rocking!!!
i ll keep you posted!!!
