Problems with Blackmagic Intensity Shuttle USB 3.0
Furor Des Wahnsinns
on Apr 18, 2012 at 5:23:06 pm
Hello =)
At the first sry for my bad english ;) i am from Germany and i dont find any german Support Hotline ore Forum for Blackmagic Products =(
I Have buyed the Intensity Shuttle USB 3.0... The Problem is it dont work with my Asus P8H67-I... It uses not a NEC USB Chip it use a Asmedia Chip... Its a Mini-ITX Board and i dont have any free PCI Slot in my Computer... Have anyone a Idea how i can use my Intensity Shuttle USB 3.0 With my Mainboard? ore must i realy buy a new mainboard? =(
Greets Akio
Jr Bergstraten
Re: Problems with Blackmagic Intensity Shuttle USB 3.0
on Jun 7, 2012 at 6:16:01 am
See if you can check out the firmware from the Asmedia chipset.
110230 works. You can check it with u.bat (Google it).
I have also an Asmedia 1042 and it doesn't work (yet).
Hopefully a firmware update of yours works but be VERY VERY careful with that as you can't go back, unless the ITX board manufacturer gives it to you.
