BM Intensity Pro issue with Sony Vegas Pro 11
Lee Wroe-Johnson
on Mar 20, 2012 at 7:28:37 am
I was wondering if anyone else using BM Intensity Pro with Vegas Pro 11/595 64bit on Windows 7 64bit had the following issue.
I am unable to view 1920x1080 50i (Pal) on my viewing monitor,it is just blank,the signal is coming from BM HDMI out. I have set the BM properties to 1920x1080 50i and in the Vegas properties match source which is 1920x1080 50i what the video is recorded in (AVCHD), I have also checked that the other BM properties are set to output to HDMI and others are set to off. ie HD to SD letter box etc, so all is correct, but nothing shows on the monitor. The monitor is full HD 1920x1080. I have tried another full HD monitor swapped HDMI leads but still no difference. So when I change the Vegas source properties to (Pal) 720x576 and leave the BM properties at 1920x1080 50i I can view on the monitor the footage but it is at 720x576. I have even swapped the BM properties to 720x576 and Vegas properties to 1920x1080 and again I can view only 720x576 on the monitor. I have also tred/changed the settings in vegas preview bypassing BM to windows graphic card (I have a Nvidia GTX570 with the latest drivers) and used one of my 2 working monitors to view the footage in 1920x1080 and it is perfect.
Any ideas what is wrong or could it be a faulty BM Intensity Pro. I have only just got it.
Your help and advice is most appreciated.
Lee
Lee Wroe-Johnson
Re: BM Intensity Pro issue with Sony Vegas Pro 11
on Mar 22, 2012 at 8:39:34 am
Anyone ....please
