ATEM TVS embedded audio question...
Robbie Brandon
on Mar 19, 2012 at 9:34:42 pm
DOes the ATEM TVS embed audio to the SDI and HDMI program outs via the AES/EBU connector? I have got confirmation that the ATEM 1 M/E embeds the audio into the SDI/HDMI program outs, but i also heard the TVS only embeds to the H.264 stream out of the usb2.0 output. Can anyone confirm on way or the other?
Jeff Hartman
Re: ATEM TVS embedded audio question...
on Mar 20, 2012 at 12:24:43 pm
[Robbie Brandon] "DOes the ATEM TVS embed audio to the SDI and HDMI program outs via the AES/EBU connector? I have got confirmation that the ATEM 1 M/E embeds the audio into the SDI/HDMI program outs, but i also heard the TVS only embeds to the H.264 stream out of the usb2.0 output. Can anyone confirm on way or the other?"
Yes, the AES feed you supply does indeed get embedded in the SDI and HDMI outputs, and becomes part of the H.264 stream. The AES input is unbalanced and needs to be at 48K sample rate.
-- Jeff
Robbie Brandon
on Mar 21, 2012 at 9:39:46 pm
Thats exactly what I needed. Thanks!
