Blackmagic Design HDLink Pro DVI - bigger screens than 30"?
Aleksander Steffensen
on Mar 7, 2012 at 12:52:13 pm
Hi!
I am considering purchasing several HDLink units to use with 42" monitors that are part of a TV studio. I figured this is a considerably cheaper way to get SDI into the monitors, rather than buying dedicated SDI I/O cards for the monitors.
However, after reading the specs on BMD's website, I noticed that they say "Supports SD, HD and 2K using Dual Link DVI-D displays up to 30 inches 2560 x 1600 in size.". This might be a stupid question, but does this really mean that the HDLink cannot be used to send a 1080p DVI signal to a 42" monitor, only up to 30"?
Thanks in advance!
Steffensen Multimedia
Kristian Lam
Re: Blackmagic Design HDLink Pro DVI - bigger screens than 30"?
on Mar 7, 2012 at 10:52:48 pm
The requirements are really referring to Dual Link DVI-D displays up to 2560x1600. The size of the screen does not matter.
If you're going to be sending your DVI signal to a 42" display that is just 1920x1080, it will be fine.
regards
Kristian Lam
Blackmagic Design
on Mar 7, 2012 at 11:24:54 pm
Excellent! Thank you, Kristian!
