ATEM TVS/H264 Pro Recorder streaming/recording software MX Light Updated
Richard Freemantle
on Mar 2, 2012 at 5:45:17 am
MX Light has been updated to version 1.2
Now includes support for the ATEM TVS's/H264 Pro Recorder's internal hardware scaler. Allowing fine grain control of output resolution.
Further information can be found here http://www.mxlight.co.uk . An updated demo version is available on the download page.
For those that may have missed it before:
Feature overview:
* Streaming support
* Allows full HD interlaced capture
* Fine grain control over output resolution
* Optional preview (record/stream using only a few % cpu)
* Super-compact interface
* Fast operation via global keyboard shortcuts
* Minimum hardware requirements
* Works on XP, Vista and Window 7
If you have any questions feel free to ask.
Richard Freemantle
Mike Squires
Re: ATEM TVS/H264 Pro Recorder streaming/recording software MX Light Updated
on Mar 5, 2012 at 5:26:30 am
Rich,
Just wanted to let you know that we got HD capturing working just fine, though it was capturing at 25fps, not 29.97. We haven't tried out this latest version, which allows you to change the frame-rate on capturing, but I will late this week.
Regardless, so far, so good.
What I really need is a way to stream to Ustream, and I'm sure it can be done, I just haven't had a chance to mess with it too much. I'll need Ustream come August.
Keep up the good work, we all appreciate it.
Patrick Sproule
on Mar 8, 2012 at 6:53:35 pm
We will be looking to this one as well to see if we can use it to live stream Youtube events. One issue for us though may be Youtube needing specific bit rates etc that the H.264 Pro Recorder might not be able to be set to. Otherwise I guess it's back to Adobe FME and a big CPU load.
Richard Freemantle
on Mar 12, 2012 at 3:20:52 am
Hi Patrick,
MX Light allows fine grain control over audio/video bitrate & frame size. So I dont think this should be a problem. Version 1.3.0 should be available within the next few days, if you would like to have a play with the demo.
Richard Freemantle
on Mar 15, 2012 at 6:18:28 am
MX Light v1.3.0 has now been released & an updated demo is available on the download page here : http://mxlight.co.uk/download.html
Changes in this update:
> Added Failsafe recording mode
> Extended integration possiblities for 3rd party tools
> Fixes mp4 conversion issues
> Numerous other improvements & bug fixes
Richard Freemantle
Richard Freemantle
on Mar 12, 2012 at 3:16:54 am
Hi Mike,
Glad to hear it you got it working. Re: frame rate changes, the encoder only allows frame decimation eg. 50fps > 25fps, 59.94 > 29.97, 60fps > 30fps. So, its somewhat limited but still useful in a number of scenarios.
There will be another minor update coming in the next few days (hence the delay in response!) which will make the resampling setup a little easier & more robust.
