Format change SD/HD on ATEM control panel
Nemeskeri Kornel
on Feb 22, 2012 at 5:23:41 pm
Hi!
Anybody know where I can switch the resolution (SD/HD) of the mixer in the controller menu?
On the sotware control panel is simple, settings format...
But i can't find in the 1 M/E control panel.
Ryan Bedell
Re: Format change SD/HD on ATEM control panel
on Feb 22, 2012 at 5:45:23 pm
As far as I can tell there is no way to do it from the panel. Also you can't customize the multiview and you can't rename sources (unless I'm REALLY missing something).
But the software panel works well for all the settings.
Ryan
Nemeskeri Kornel
on Feb 22, 2012 at 8:23:33 pm
Unfortunately, this is quite a big problem .... but I hope soon to correct this little problem.
Otherwise, we are very satisfied with the equipment knowledge.
Thanks Ryan
