INTENSITY PRO - recording on DVCPRO device material from hard disk
Marko Nikolić
on Feb 19, 2012 at 12:13:17 am
I need to transfer standard definition material from hard disk to DVCPRO cassettes. Can I do it with INTENSITY PRO card?
Mike Squires
Re: INTENSITY PRO - recording on DVCPRO device material from hard disk
on Feb 22, 2012 at 12:03:39 am
Sure, SDI out of the Intensity to SDI in of the DVCPro. Or component video, either way.
EDIT:
Sorry, forgot the Pro didn't have SDI I/O, but you can still use component.
Marko Nikolić
on Feb 22, 2012 at 1:37:05 am
Nice, thanks!
However, I am now having problems installing the card on Win7. Although the installation goes ok, the device doesn't appear in device manager. Any thoughts?
Mike Squires
on Feb 22, 2012 at 2:57:41 pm
Are you installing the latest Desktop Video 9.1 drivers? I'm using the Intensity Shuttle, but installation should be the same.
-Install card
-Boot computer (it should find the hardware automatically and try to install drivers)
-Install Desktop Video 9.1 drivers
-Reboot
Then run Media Express to try a test capture.
Marko Nikolić
on Feb 22, 2012 at 3:17:23 pm
Yes, 9.1.
Thanks, did it all, however - cannot see it in device manager. Media Express does not except mpg2 nor DV avi files. I will be (hopefully) using it to transfer material form hard disk to DVCPRO player, not for capture.
Mike Squires
on Feb 22, 2012 at 3:26:48 pm
When you say Device Manager, do you mean Windows Device Manager, or the "Device" drop down menu in Media Express?
If the Intensity isn't showing up under "Device" in Media Express, than yes, there is a problem. You'll need to get that sorted out first.
If that's the case, maybe in Bios the PCI-E slot is turned off, or quite possibly, the card isn't fully seated in the slot. (I've had that problem a time or two)
Marko Nikolić
on Feb 22, 2012 at 3:30:21 pm
quite a relief - I was thinking of Windows Device Manager. Media Express shows Intensity PRO under DEVICE pulldow menu. How come it doesn't appear in WIN Device Manager?
Mike Squires
on Feb 22, 2012 at 3:38:59 pm
I'm not sure, it's probably hidden away somewhere in there.
Anyway, now you need something that will play back your files, and use the Intensity as the output device. Something like Premiere Pro CS5.5 would work.
Marko Nikolić
on Feb 22, 2012 at 6:06:09 pm
I suppose Premiere CS4 would work as well?
Mike Squires
on Feb 22, 2012 at 6:09:12 pm
It should work just fine in CS4.
Jay Bloomfield
on Feb 22, 2012 at 10:23:44 pm
It should show up under "Sound, Video and Game Controllers" as two items:
1. Blackmagic Driver
2. Blackmagic Audio
Marko Nikolić
on Feb 22, 2012 at 10:42:48 pm
I see, it does show like that. Seems to be working now. If anything changes - I'll shout again :-)
Thanks!!!
Marko Nikolić
on Feb 24, 2012 at 1:07:48 am
works nicely, however, now in playback I get a strange thing...
Every 12-13s picture seems to jump down a bit and gets back.
Marko Nikolić
on Feb 24, 2012 at 2:06:05 am
forgot to mention that I'm playing from Premiere CS4, using PAL SD 25fps interlace, lower field first.
