HDV camcorders with ATEM
Liudas Vasaris
on Feb 15, 2012 at 11:43:25 pm
I'm interested in using HDV camcorders (canon xha1, sony fx1 etc.) with ATEM switchers. As i know ATEM already suport SD, so with 720 x 576/50i resolution I shouldt have any problems, right?
What about 1440 x 1080/50i? Would ATEM recognize this as 1080i50? If conecting XHA1 to ATEM via BM analog(component)->SDI maybe it would be up-converted to full HD and ATEM recognize this as 1080i50?:)
Justin Strauber
Re: HDV camcorders with ATEM
on Feb 16, 2012 at 4:33:19 am
Not entirely sure in your case, but you would probably need an UpDownCross after the analog->SDI converter in order to get things to the right format. I don't have an HDV camera, all of mine are straight 1080i, so I can't tell you with certainty.
Liudas Vasaris
on Feb 16, 2012 at 8:01:35 am
There are many threads about XHA1-component and possibility to output 1920x1080, but as I understood it just upscale 1440x1080. I was wondering maybe converter upscale signal as well?
Martin Kraut
on Feb 16, 2012 at 11:10:39 am
I think the XHA1 will output FullHD on the analog output connection and not 1440x1080. It means that your camery will automatic upconvert from HDV to FullHD
Liudas Vasaris
on Feb 16, 2012 at 11:40:06 am
Thanks. As I thought:) Probably same with all HDV camcorders like fx1?
One more big advantage for ATEM!
