HDLink Pro DisplayPort
Neil Sadwelkar
on Feb 11, 2012 at 4:03:38 am
I tried searching but could not find a precise answer of recent enough date.
Does the BM HDLink Pro DisplayPort work with the Apple Cinema 27"?
What kind of a DisplayPort to mini female DisplayPort adapter is needed?
Will this arrangement output 1080p HD as scaled to 2560x1600, or 1:1 'windowed'?
Will this arrangement output 2k via a BM Extreme HD3D card over 3G HDSDI?
Is anyone actually using this as a monitor?
Is there a list of monitors qualified for use with the BM HDLink Pro DisplayPort?
Finally, will the new 27" Thunderbolt Cinema Displays work with the HDLink Pro DisplayPort?
Neil Sadwelkar
neilsadwelkar.blogspot.com
twitter: fcpguru
FCP Editor, Edit systems consultant
Mumbai India
Arun Kumar
Re: HDLink Pro DisplayPort
on Oct 26, 2012 at 1:30:58 pm
Hi Niel,
I am using same setup as you mentioned above.
1. Apple Mac Pro -
2. Decklink HD Extreme
3. Resolve 8.2
4. HD Link Pro ( Display Port )
Did you happen to find a way to VIew 2k output on Apple Display ..??
Connection :
BM Decklink Extreme --> SDI --> HD Link Pro --> Displayport --> Displayport to Mini Display Port --> Apple 27" Cinema Display
