Ultrastudio SDI output levels
Menno van Dijk
on Feb 9, 2012 at 9:23:32 am
Hi I was wondering if anyone could help me out.
I am running After effects (CS 5.5) on Windows 7.
Using a BM Ultrastudio USB3 connected to a FSI broadcast monitor.
The thing is when I have a HD comp with 0 black and 255 white levels, an 8-bit comp in this case, the scopes on the monitor always show 16-235 values? So the Ultrastudio is adjusting the signal?
I understand those are broadcast save values and the image looks the same as on my monitor (only better because the broadcast monitor is calibrated).
But I should be able to see illegal values on the scopes so I can correct them?
© 2018 All Rights Reserved
