Decklink SDI for SD streaming - can I superimpose a graphic?
Cian O'Carroll
on Feb 6, 2012 at 5:17:03 pm
I am using a Declink SDI card to stream SD live events, and to stream replays after the event has finished.
I would like to add an on-screen graphic to say "Live" or "Recorded Earlier".
Will I be able to do this on a single card - In other words, does the card put the overlay the graphic before the video gets to the streaming encoder or after?
C.
Cian O'Carroll
Re: Decklink SDI for SD streaming - can I superimpose a graphic?
on Feb 13, 2012 at 4:19:07 pm
I have found that the answer is no! When you use the board as a streaming card, the LiveKey software tells you that the card is in use by another process.
I had a second decklink SDI card handy, so I now have one as the Keyer and one as the streaming card.
C.
