9.2 Beta 1 driver - No Joy
Bruce Colgate
on Feb 6, 2012 at 3:15:37 pm
Howdy.
Don't know if I'm the only one, but working on a Multibridge Pro, the 9.2B1 drivers aren't worthy. In FCP7, buffering lag brings editing to a standstill, and in FCP10.0.3, only SD is available, and while the computer display of the sequence is fine, the BMD output is seriously delayed, along with frame skipping.
- Bruce Colgate
Caio Simbula
Re: 9.2 Beta 1 driver - No Joy
on Feb 6, 2012 at 7:57:48 pm
I am experiencing the same issues with an Intensity Pro installed in a MacPro 1,1 runing OS 10.7.3.
caioFILM
caiofilm@mac.com
http://web.mac.com/caiofilm
Juan Salvo
on Feb 7, 2012 at 1:16:31 pm
You have to set the video format in the system preferences panel to match your sequence... Then restart fcpx. You'll need to change the setting in system preferences and restart fcpx everytime you want to change format. It certainly is beta software.
Eric Santiago
on Feb 10, 2012 at 6:18:46 am
Im not even getting the so called AV option in FCPX anywhere?
I set my prefs up to 1080p 29.97 which is the same as my projects.
I see the info in the BM control panels about FCPX but no AV option in FCPX app to be found?
Juan Salvo
on Feb 10, 2012 at 6:23:10 am
Are you using the FCPX free trial? It doesn't support AV Output,
Eric Santiago
on Feb 10, 2012 at 12:54:56 pm
Nope, Ive had FCPX since day one.
Its v10.0.3.
Also tried deleting then downloading again.
Ill wait till I hear something from BM support.
